Adding caps to Castle Creations ESCs
lostrack
London, UK
Hello EV gurus!
So - I've seen more than a few builds adding more capacitors to Castle Creations controllers.
*edit*
I have done some research and and copying/pasting what I found here. Hope it will be helpful.
http://www.rcgroups.com/forums/showthread.php?t=952523
Problem
Conclusion from the links below, all controller manufacturers say the same:
Too long battery wires will kill your ESC over time!
The standard input capacitors (large cylindrical thingies in thin shrink wrap) will be destroyed over time because they get warmer/hotter. Using thicker wire will not help, it's mainly a wire inductance problem, not a resistance problem.
This goes for all makes, they all use the same principle (except Sinus controllers, they use sinusoidal commutation instead of trapezoid, they tested 70 meters without capacitors). However, lengthening the motor wires may lead to radio interference. Give the three of them a twist to prevent this.
Solution
Lengthen the motor wires, not the battery wires. That's hardly critical because there's already a lot of wire in the motor itself. If the motor-ESC wire eventually gets too long, it will not harm motor and/or controller. May cause interference though, give the motor-ESC wires a twist. Always a good idea to do that anyway.
Rule of thumb
If you have to lengthen the battery wires, add extra electrolytic capacitors in parallel with ESC, never in series with ESC. As a rule of thumb, for every 4inch/10cm extra length/distance between battery and ESC, add an 220uF extra capacitance near the controller (electrolytic condensators, voltage the same as the capacitors already installed, low ESR type) (Ludwich Retzbach, German e-flight author&editor, the 'R' in LRK).
Better to use several smaller caps (in parallel) instead of one biggie. Smaller caps can shed more heat and total inductance will be lower (inductance per cap is lower and those inductances are paralled to boot ). See attached pictures below.
Also keep the positive and negative wires as close to each other as possible, eg. by twisting and/or taping them together. If the wires are close to each other then the series inductance will be reduced, because the current is going in opposite directions in each wire (and therefore producing opposite polarity magnetic fields which cancel out). For example, 13AWG wires separated from each other by 1 inch have about 4 times higher inductance than if they are bound together. (Bruce Abbott in http://www.rcgroups.com/forums/showthread.php?p=11594609#post11594609)
Capacitor type
The main spec you need is low impedance and low ESR(equivalent series resistance). I think the only thing you will find at radio shack will be general purpose caps, not low ESR. The ESR of a cap won't be printed on it, you will have to look up the manufacturers spec sheet. The Rubicon ZL series mentioned in the Schulze instructions is a good one and is available from newark/farnell. The Panasonic FM series is another good low impedance cap and is available from digikey
www.farnell.com/datasheets/2161.pdf
industrial.panasonic.com/www-data/pdf/ABA0000/ABA0000CE108.pdf
PS You would want the voltage rating on the caps to be significantly higher than the battery voltage. Same voltage rating is the installed caps. Higher rating is no problem. (thanks jeffs555, from http://www.rcgroups.com/forums/showthread.php?p=11971048#post11971048)
If you try it with longer wires and no extra low esr caps it may work for a while, but the longer wires put an extra load on the original cap. The extra load shortens the life of the original cap and it will eventually fail, probably catastrophically. (thanks jeffs555, from http://www.rcgroups.com/forums/showthread.php?p=11996840#post11996840.
Capacitor polarity!
Electrolytic capacitors, like batteries, have a (+) and (-) lead! Solder them in the wrong way and they will got hot, pop open or even explode. Nasty fumes and the liquid stains. Don't ask how I know
How to add extra capacitors (English and German)
www.schulze-elektronik-gmbh.de/guide/gfutc-de.pdf
YGE controllers, extra capacitors and their location, nice pics, click to enlarge:
www.yge.de/caps2.php
Expert opinions, rules of thumb, installation
Schulze controllers and battery lead length
www.schulze-elektronik-gmbh.de/tips_e.htm (English)
www.schulze-elektronik-gmbh.de/tips_d.htm (German)
Castle Controllers about battery lead length
http://www.rcgroups.com/forums/showpost.php?p=1537846&postcount=28
http://www.rcgroups.com/forums/showpost.php?p=4833040&postcount=5
http://www.rcgroups.com/forums/showpost.php?p=1531363&postcount=25
www.rcgroups.com/forums/showthread.php?t=1095329
Bob Boucher (Astrobob, www.astroflight.com) on long battery leads
http://www.rcgroups.com/forums/showpost.php?p=2988042&postcount=32
Hacker on long battery wires:
www.hacker-motoren.de/images/Master-manual-Engl.pdf (English)
-> Safety and operating instructions
www.hacker-motoren.de/images/MASTER-Manualgerman.pdf (German)
-> Sicherheits- und Betriebshinweise
Novak
www.teamnovak.com/tech_info/power_caps/power_caps.htm
Paul Daniels
http://www.rcgroups.com/forums/showthread.php?p=11297012#post11297012
Explanation/theory
First a watery analogy, water running in a pipe and through a tap. Now turn off the tap quickly. You'll hear a loud knock/shock sound in the pipe. The water wants to continu flowing but it can't, for a moment the water pressure is much higher than the static water pressure. It's the same for a current that's switched off, because of the inductance it wants to keep on flowing, voltage gets higher. This is also what causes sparks (brush fire) in a brushed motor.
The controller is like a watertap that's switched off (and on) very fast (8,16, 32kHz PWM) to get the desired current. Turning off the current, in combination with the battery wire inductance, causes voltage spikes because the current wants to continue on its course (ref. inertia of the moving watercolumn). Those voltages are higher than the battery voltage. The input capacitors (cylindrical) takes care of these spikes (they reduce the wire inductance). The longer the wires, the higher the voltage spikes induced in the wires, the harder on the input capacitors. They will get warmer, heat up and explode. This is caused by the wire inductance, not by wire resistance. Therefore, using thicker wire will not help much, it's not a bad idea either, but extra capacitors are the solution, thus reducing/compensating the wire inductance. Or longer motor wires instead of long battery wires.
www.s4a.ch/eflight/reglerleistung.pdf (German)
-> Akkukabellänge und seine tödliche Auswirkung
The coils switching off create the high voltage spikes in the battery wires:
http://www.rcgroups.com/forums/showthread.php?p=10940134#post10940134
In depth discussion
www.aerodesign.de/peter/2001/LRK350/SPEEDY-BL_eng.html
http://www.aerodesign.de/peter/2001/LRK350/Warum_dreht_er_so_eng.html
http://www.rcgroups.com/forums/showpost.php?p=10028325&postcount=2661
http://www.rcgroups.com/forums/showthread.php?p=1518827#post1518827
Measurements
By RCGroups user Peter D Rieden
http://www.rcmf.co.uk/4um/index.php/topic,50366.msg569630.html#msg569630
Vriendelijke groeten Ron van Sommeren
• brushless motor building tips & tricks
• diy brushless motor discussion group
• Drive Calculator download & discussion group
• int. electric fly-in, Nijmegen, the Netherlands
DIY pictures
more pictures at www.YGE.de controllers
Han Witteveen (Netherlands ) posted his diy solutions in post #49
Building the Haviland DH-84 VH-UXG 'Riama' workshop cam
Added the castle cap pack (4 extra low esr caps) to the hv160, on a 2kw run the ripple was less than 1v. Think it's working!
Have added a Pre charge circuit as the inrush current is apparently higher with caps.
Prolly a good time to bring this topic back to the front page for the newer membership.
http://endless-sphere.com/forums/viewtopic.php?f=28&t=7504&hilit=adding+caps+to+castle+controllers
from castle creations:
http://www.castlecreations.com/products/cc-cap-pack.html
hi,
does anyone know if it is safe to add a "anti-spark" connector to a CC ICE HV160A Controller?
on this site is a note about not using one with the Mamba controllers, but i am not sure this applies to the ICE HV controllers.
http://scriptasylum.com/rc_speed/nospark.html
Important Note: Do NOT use a pre-charge resistor on the Castle Creations "Mamba" line of speed controllers. Due to the way these controllers are designed, using a pre-charge resistor may render the unit inoperative. This has been confirmed by Mr. Patrick del Castillo, president of Castle Creations.
nieles said:
hi,
Hi Nieles,
Speaking for myself, I've successfully wired a low current switch in parallel with a high current switch, with a 10 watt resistor in-line. After a few seconds, there is a residual charge and less of a spark when the high current switch is turned on. There's still a spark...but it's contained within the high current switch and the popping nosie is much quieter.
The ESC does make a quiet hissing noise as it struggles to start up though...
So yes, it is.
A while back there had been two fairly large threads on adding capacitors to ESCs. Thud listed one of them in his post just above, and here's a link to the other one:
http://endless-sphere.com/forums/viewtopic.php?f=30&t=22194&start=45
