docw009
You've already got $1700 into this. Why risk damaging the battery with a soldered up kluge? I would suggest spending some more for a spot welder and giving it your best shot. Then the next battery will be cheaper.
docw009 said:You've already got $1700 into this. Why risk damaging the battery with a soldered up kluge? I would suggest spending some more for a spot welder and giving it your best shot. Then the next battery will be cheaper.
Headrc said:Can I ask what are the physical dimensions of this pack? Also, which LG cell did they use in this pack? Do you know the discharge rate of the cells?
Headrc said:Interesting approach of buying a Chinese pack and making improvements here ...and some good ideas on improving it.
hemo said:A battery and a half, good work in bettering it.
tolkaNo said:Really nice work man but you obviously could have built the whole pack by yourself to begin with :lol:
madin88 said:... i would add a drop of CA in each gap where the series cells touch. This should add support to the insulation and make it stiffer.
MJSfoto1956 said:Maybe. Certainly my unboxing has illustrated what someone is likely to receive from a typical AliExpress vendor -- one can only assume that this level of build would be considered "good enough" for the masses in China. I think the unveiling shows how they can and will cut corners wherever they can.tolkaNo said:Isn't that pack built pretty badly?
furcifer said:I have no doubt had you asked for "more" and paid for "more" they would have provided "more". They did for me. Andy answered all my emails and technical questions very quickly and honestly.
