dnmun
1 PW
you can test the output mosfets on the controller to see if they are functional. use the diode tester function on the voltmeter.
test for ths source drain body diode in the output mosfets. the drain is always higher in voltage in the controller so you wanna look at the source-drain body diode by testing with the diode tester between the RED power wire and each of the phases and the BLK ground wire and each of the phases. test both directions. 12 measurements.
it should conduct, when the body diode is forward biased, and it should show open circuit when the body diode is reversed.
