ElectricGod
Animalector said:" Can you 3D Print (ABS) plastic cyclone gears ?? "
absolutely yes.... Do they work... hmm not so much
- I removed the motor,
opened the gearbox,
installed the gears,
ran the motor on the bench
Hmm, sounds good
- reinstalled the motor,
test run with the wheel off the ground
hop on
start riding very gently,
so far so good, 1/2 way around the yard
apply some more throttle
gently
**CRUNCH** bzzzzzz
I didn't even make a full lap
Just say "NO!" to planets. No motor needs them. If you can't do real gearing external to the motor, then why add unreliability internally to the motor? Planets are bad, external gearing is good.
