Guess I found my next FET
The IPP023N10N5 is TO-220 FET with only 2 mOhm typical @ 100 amps and 10 volts.
Gate capacitance is only 10 nf - Current UCC drivers could handle up to a 36-FET board.
Avalanche characteristics look great - Max avalanche current is 100 amps/FET for 10 us
Miller capacitance is only 80 pf, resulting in 0.7 volts max miller-induced gate bounce
Threshold voltage is a bit low at 3 volts, but a diode and resistor per gate drive channel would fix this pretty easy
Not made in China
Infineon parts have good reputation for quality and durability
Only $2.66 apiece if buying 25 at Arrow - Once I exhaust their supply of 54, only $3.83 for 100 at Mouser.
Edit: Newark has them at 2.29 per piece but shipping only makes this economical if buying 50+ parts
Unless you guys see anything wrong with this FET it's probably what I'll use for the version of the controller that I will initially sell. Right now, I'm looking at a sandwich-style design to minimize size.
First layer will be the heatsink.
Second layer will be the power board, with decoupling, 24 FETs, drivers, and current sensors, and space for the wires
Second layer will connect to the third with elongated header pins. I'll put some sheet aluminium between the second and third boards to shield from noise
Third layer will consist of power supply and brain board.
The controller will be around 2 inches wide, 6 inches long, and 3 inches deep.
Peak phase current will be 400 amps, and 200-250 continuous.
48-FET version could do 800 peak amps and 400-500 continuous for ~1.5x the BOM cost of the 24-FET
