I'm no expert, buit I was a newbie recently enough that I remember some of the questions I had trouble with. So here's a few answers.
Q1. What multimeter should I buy?
A1. Anything. I just did an Ebay search, the cheapest one that came up was about $4, and it looks to me to be just fine for diagnosing e-bike issues or anything else I use a multimeter for.
Q2. What's a C value?
A2. If you buy a 5 amp-hour 20C battery, that means that it can give you 100 amps under load (or so the vendor claims). As in so many things, vendor claims are sometimes optimistic, of course. Another exaple - a 3 amp-hour 40C battery should be able to give you 120 amps.
Q3. What's 4s2p?
A3. 4s means four cells in series - if they're Lipo, that's 3.7 volts each (nominal) so 14.8 volts (nominal). When fully charged, that would be 4.2 volts per cells. The 2p means two of these in parallel, thereby doubling the capacity. So you can now see what, for example, 12s3p would mean.
Q4. How thick to my wires need to be?
A4. That depends on how much current they'll carry. And on other factors, such as how easy is oit for them to lose any heat they get. Here's a table I found:
8AWG 200 amps
10AWG 140 amps
12AWG 90 amps
14AWG 60 amps
16AWG 35 amps
18AWG 20 amps
20AWG 12 amps
22AWG 10 amps
Here's another table I found:
8AWG 95A
10AWG 65A
12AWG 45A
14AWG 32A
Q5. What's the relationship between volts, amps and watts?
A5. Watts = amps times volts
Q6. What's the safe way to handle Lipos?
A6. Read this: http://www.icharger.co.nz/articles/ArticleId/3/Lipo-Lithium-Battery-Safety-Guide.aspx and this http://www.mpoweruk.com/balancing.htm
Q7. Is there an FAQ?
A7. http://endless-sphere.com/forums/viewtopic.php?f=3&t=26488
Q8. Is there a wiki?
A8. Yes, here: http://www.endless-sphere.com/w/index.php/Main_Page
Q3. What's 4s2p?
8AWG 200 amps
10AWG 140 amps
12AWG 90 amps
14AWG 60 amps
16AWG 35 amps
18AWG 20 amps
20AWG 12 amps
22AWG 10 amps
8AWG 95A
10AWG 65A
12AWG 45A
14AWG 32A
