I run my Crystallite X5303 completely stock on 84V @ 40Amps, and have no issues at all.
Because the 5303 draws amps all through its power curve it is very hard on the controller though, so all my issues have been controller related rather than motor related (my hub has never skipped a beat). I find that at 84V @ 40Amps i put out about 3,000Watts, and the stock motor phase wires get warm, and the motor hot, but all runs fine.
However, when I started I did not appreciate how much amps the 5303 consistently draws, so I started with a 12 Fet controller and melted the phase wires where they come out of the controller. I moved to an 18 Fet controller and the controller actually exploded because it got so hot the solder melted in the controller (I was, however, not giving the controller adequate airflow so i am sure that contributed). So now I run a 24 Fet controller and everything runs a dream.
On this topic though, I have often wondered at what point in Amp increase I would need to upgrade the phase wires from the stock ones, as they do get toasty but are fine at this point. At 84V @ 40amps I can reach 80km/h on a flat, so I have never felt the need to up the amps like some of the maniacs here.
I have been curious at what combination of volts and amps people feel that the x5s need to get bigger phase wires/cooling holes etc.. I may be running close to that mark, as I said, the motor is hot to the touch for about 10 mins after riding, but I have done nearly 800 km with no issues.
