benj
- Joined
- Jun 6, 2013
- Messages
- 242
Hey everyone,
Thanks to Marcin my VESC arrived and is all fired up and wired up. Detection worked smoothly and I have great control using the BLDC tool.
However I can't seem to figure out PPM control. It's kind of 'all or nothing'. I've read that Vedder hadn't tested it that much, but hoped that was kind of old news.
I have set the Minimum and Maximum Pulsewidth based on the live display, and now the live display looks great, moving from zero to full with the throttle position.
However, the motor doesn't spin up until about 50% throttle is pressed and when it does,the motor runs at max speed straight away. I tried changing the deadzone but that didn't seem to make much difference.
Releasing the throttle stops the motor dead, almost like the brake is coming on.
This is all on a bench, no load on the motor at all.
Am I missing something? Shouldn't I be able to hold an RPM based on throttle position?
Thanks for any tips.
Ben
Ben
