davespicer
My (older-model) eZip Trailz from Wal-Mart has the 250-watt MY1018 (2 3/4" housing). I finally got around to trying a 36-volt SLA pack on it, which the older controller was okay with. Lots more speed, a banshee whine from the gears... and of course some extra heat inside the motor. It didn't take long to get noticeably warm.
Looking at the various MY1018s at http://www.electricscooterparts.com/motors.html it seems that the 450-watt models spin about 44% faster than the 250-watt ones. That's be the difference between say 17mph and about 24 mph, which is enough for my needs... and about what the overvolted 24-volt 250-watt motor seems to be giving me.
So it looks like I could switch motors and get about the same speed from the beefier (3 1/2" housing) 36-volt, 450-watt motor as I am now. With the same controller, the current wouldn't change so the power input to the motors would be the same. And the 36-volt motor would surely run a lot cooler than the 24-volt one is, being more efficient and lasting longer (maybe a lot longer).
This looks pretty appealing to me, since it'd be a straightforward bolt-on swap. Have any of you folks done this? Um, and I also need to ask, is any of my reasoning faulty? I've been known to forget pretty basic stuff from time to time... :?
