Would like to do a build using a 12V power system running off of 4s LiFePO4 prismatic cell pack (3.2V per cell = 12.8V). Reason being that then I could direct wire big bright full size LED tail lights, bright LED 12VDC track light bulb(s) as head lights, and maybe even a horn directly to the main pack without a DC/DC converter for reliability (lots of night commuting where I take the bus with the bike in the rack to work and coming home late at night with no bus available) not to mention the ability to charge off of any 12V power source and use a lead acid type 12V battery charger (like available in the shop at work) on the lowest charge setting to top off the bikes battery.
So, Anyone tried running a stock wound RC low-Kv(130-200) 6374 or 6354 motor on only 12V? RPM's should be low enough to only need a one step gear reduction to reduce to mesh with the main drive chain and synchronize with pedal power. The specs. on some of them say that that they can go down to 4s Li-Po cells which would be 14.8V (3.7V per cell = 14.8V) so is dropping another 2V below that enough to brown out to burn out or should it be good to go? Plan would be to use the new CA to provide throttle signal to an RC brush-less motor controller and to limit current down to a max of 40-50A or so and run as a 500-600 watt mid-drive. Probably do a simple contact button throttle and program ramp up and ramp down in the CA to smooth out the on/off simplicity (which is all I need for a low wattage low voltage set-up since I pretty much use my current low wattage bikes as basically on/off for the motor assist).
