DotScott
1 W
- Joined
- Feb 6, 2016
- Messages
- 52
Hey everyone,
I have a Cycle Analyst 2.3 connected to my ebike build but I noticed today that when I start to get up to higher speeds (might also be at lower speeds but I haven't noticed it at lower speeds yet - try to keep my eyes on the road), the speedometer reading fluctuates wildly. It'll jump from 45 to 70 and then down to 52 then 64 all within a split second. Anyone have any idea what the problem might be? I'm sure I just have a setting off somewhere or something but... I can't tell where.
Here's my setup, controller settings and and Cycle Analyst settings:
SETUP:
- Controller: Sabvoton SVMC 96120
- Battery: 86v (~72v min and 97v max). I currently have it limited to 50 amps but can output a max of 80 amps continuous.
- Display: Cycle Analyst 2.3 with 150A 0.5 mOhm shunt (this isn't working correctly for some reason though).
- Throttle: potentiometer type - Magura Twist Grip Throttle 0-5K Ohm.
- Variable Regen throttle: Hall type thumb throttle.
- 3-way speed switch (I honestly can't tell which is high, medium or low. They all seem the same because the acceleration is so slow.
- Brakes: Tektro Dorado e-brakes (disk).
- Headlight: Fisher Fab House Ultra 3200 LED E-Bike Light connected directly to main bike battery.
- ignition: key switch.
- Shunt: 0.5 mOhm external shunt for CA-HC, up to 150A continuous, 400A peak https://www.ebikes.ca/shop/electric-bic ... nt0-5.html
CYCLE ANALYST SETTINGS:
- Set Wheel: 2155 mm
- Speed limit: 95mph (throttle is not attached though as I don't need to control throttle through Cycle Analyst).
- Amps limit: 97A (throttle is not connected to CA so it doesn't matter).
- Low Volts Limit: 74v (again, shouldn't be relevant due to no throttle attached to CA).
- Main Display: Watts
- Set Range: High (0.1A)
- Averaging: 5
- Set RShunt: 0.500 mOhm
- Zero Amps: N/A (blank) (don't know what this should be set to)
- Volt Sense: 31.27 v/v
- Set #Poles: 16 - this might be affecting it. I believe I have this right though. QS205 50H V3 says it has 16 pole pairs.
- PSGain: 0.08 V/mph (don't know what this should be set to)
- IntSGain: 200 (don't know what this should be set to)
- IntAGain: 300 (don't know what this should be set to)
- IntVGain: 800 (don't know what this should be set to)
- ITerm Max: 3.79v (don't know what this should be set to)
- ITerm Min: 0.49v (don't know what this should be set to)
- Max Throttle: 4.98v (irrelevant since I don't have the throttle running through the Cycle Analyst)
- Set Ratio: 0.0993 LG/HG (no idea what this should be set to)
- Serial Output: 1 Hz (don't know what this should be set to)
- Aux Voltage: Off
- Aux Thresh: 0.99v
- VShutDown: 10v
SABVOTON CONTROLLER SETTINGS:
BASIC:
- Lack volt: 74v
- Over volt: 115v
- dc limit current: 70A
- Rated phase current: 150A
- Max Phase current: 300A
- Protected phase current: 400A
TEMP:
- Unwork temperature: 90
- Rework Temperature: 80
- Limited current temperature: 70
FUNC:
- Electric brake: enable - I have variable regen braking enabled but it's barely working right now.
- electric brake ph current: 50A (I'm still figuring out what to set this to).
- Boost/3 Spd: 3 Speed Switch - though I can't really tell if it's working or not...
- Cruise: disabled
- Reverse speed limit 20% (I don't use this though).
- Flux Weakening: enabled
- Flux weaken current: 30A (could this be affecting the speedometer somehow?)
- Reginerative charge: disabled
- Slide regenerative charge current: 50A
- Slide regenerative charge speed: 100rpm
THROTTLE:
- Throttle min volt: 0.4
- Throttle max volt: 5
- Acceleration time: 50
- Deceleration time: 50
- Throttle mid volt: 2v
- Throttle mid current: 90A
MOTOR:
- Motor direction: 1
- Motor Pn: 16
- Speed limit mode select: no limit
- Motor limit speed set: 100%
- Low speed set: 45%
- Middle speed set: 75%
DEBUG:
- Current loop kp: 999
- Test given current: 0 - not relevant unless testing.
- Hall angle test: disabled (not relevant unless testing).
- Hall angle: 243
SETUP:
- Averaging: 5
- Aux Voltage: Off
- Aux Thresh: 0.99v
- VShutDown: 10v
BASIC:
- Lack volt: 74v
- Over volt: 115v
TEMP:
FUNC:
- Cruise: disabled
THROTTLE:
MOTOR:
- Motor Pn: 16
DEBUG:
- Hall angle: 243
