ScooterMan101
eTrike,
You have me wondering what you did have , four doors , bit of a cage and topped out at 45 ?
and what you have now ?
Pict's and links on both ? I am really interested, I presently trying to figure how I could I get/buy something that is a bit of a cross between a car and MC , as I would like to get rid if my old, piece of junk car.
but do not have enough money for a used Leaf, Volt, Prius , etc.
eTrike said:Here is my story. My motorcycle has four doors, four seat belts, a bit of a cage and tops out at 45mph. I consider it an extremely safe motorcycle compared to others due to increased physical protection, the size and color makes it difficult to "not see" (indeed it turns every head), and the lower speed keeps me safer overall, but it is much less efficient as a result of its size-- about on par with a small EV car which matches its stature. It is about the size of a Suzuki Swift or Geo Metro if you're familiar with those.
When it was new, it was $12,000 with 72V Lead-acid system, 37mph top speed (decreasing to 33 rapidly) and 25mi range if you're lucky(and slow to a crawl) and takes several hours to charge
On clearance they wanted $7,000.
They can be easily found for 2-3K now, still with crappy lead-acid which most likely need replaced, hence the sale. :?
I paid $500 because it needed batteries and a controller.
$500 for new controller
$1.5-2k for high end lithium that will likely outlast the vehicle.
Now I have an errand/commuting/fun machine for which I paid $2.5-3k, is 300lbs lighter, capable of 45mph and will maintain 40mph for 28+ miles.
Converting that into petrol at its rather low cost at the moment, it would be about 1 US gallon at about $2.30. That is not factoring the wild price fluctuations which happen with petrol. Compared to about $0.50 worth of electricity-- which is often free! So for every 28 miles I might save $1.80. If used 5 days/week, 50 weeks per year that is $450 savings in fuel. It doesn't see that much use at the moment, but it could also easily do more than that if I choose as charging is rather swift, 1-2 hours depending on location.
