geeeyejo1
I originally purchased this:
http://www.ebay.com/itm/170846310527?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
to mount on my handlebars to monitor pack voltage while riding. I subsequently upgraded to a more functional Wattmeter that displays Voltage, AH, Wattage, etc. that is now mounted to my headset.
I was thinking of splicing this Voltmeter onto my battery pack leads to provide a display of pack charge while charging, confirm a full charge and show voltage when disconnected from the charger. I will be using (at least initially) the charger provided with the pack from Sunthing that has no display.
The meter only draws 15ma - assume this will not drain the pack significantly when not in use? Any concerns with doing this?
