arcticfly said:I got the same frame and is planning to put a mid enginge in it. Possebly a GNG. The frame is very solid and should be a good platform unless it is a 2005 model. A few of the 2005´s cracked in the V at the bottom of the triangle. The frames from 2006 and newer is much stronger and those frames apparently has a lifetime or 10 years warranty.
I reckon it should be a cracking bike with 3000W in it. I have bomber 888 forks and it is a wonderful bike. Can´t wait till I get a motor in it. I will follow your project closely.
Cheers
Alex
Secret1511 said:arcticfly said:I got the same frame and is planning to put a mid enginge in it. Possebly a GNG. The frame is very solid and should be a good platform unless it is a 2005 model. A few of the 2005´s cracked in the V at the bottom of the triangle. The frames from 2006 and newer is much stronger and those frames apparently has a lifetime or 10 years warranty.
Cheers
Alex
Hello Alex,
Ok nice!!! I wil follow you to!
I only need a fork. I life in the netherlands so no mountains here and no seccond hand forks.
So it will take some time to find one.
Where do you place the battery?
Hi guys!arcticfly said:Battery placement is a problem. I do not want it over the back wheel, so I will try to place them on the frame some how. Not shure yet.
I´m from Norway so no shortage of mountains... Lots of forks on ebay at times. Try the UK or German ebay.
MAGICPIE3FOCUSPOWER said:Cool build!
Hoe is de slijtage van de ketting naar de cassette en de cassette zelf?
MAGICPIE3FOCUSPOWER said:Thanks for sharing yout info.
And what about the motor noise, does anyone hear when you are riding?
arcticfly said:Pretty cool! How many AH can you fit in there?
E-Norco said:Looks very nice!
arcticfly said:Do you have step by step photos of how you made this? Wouldn´t mind to copy you on this. My build is at a stand still as I´m not sure if I want chain or LR´s belt drive. But I can still start to make a battery box... In the mean time my hub bike will have to do...
arcticfly said:Looking at my Banchee frame, and it seems I have a larger shock absorber that fills the frame more than yours. Don´t think I can fit batteries in the triangle at all. Looks like I have to use a backpack. Thank you for the explanation of your build. Back to the old drawing board...
