Milou
1 W
Hi: I have this 48V 15H lithium battery pack I would like to take apart to check on individual cells (see attached images for explanation). The unit is suppose to be 48V but it only reads 32V and will not charge beyond. Each cell look like they are flat??? In any case, given the attached images is it OK to cut out the blue covering to expose the cells? Anything special I should be careful about (besides shorting out)? What are the wires about?
Red = Positive
Light blue = Negative
Yellow & Black = ???
I imagine the square gray gizmo is the BMS? I only have a multimeter for checking. Would I need another special tool? Thanks in advance for response. Regards JJ
Red = Positive
