pwd said:pwd said:...
I have activated the BMS by momentarily applying 4V to the two wires on the left
Thanks for the info but unfortunately mine is a different board than that. The one you linked has a mini-momentary switch with it.
I received an official reply from the seller on Ali-express (IC GOGOGO Store):
Q: "Hello, I have a 7S to 16S ANT BMS. Is it possible to add a switch to shutdown or turn off the BMS? Thank You"
A: "hi friend
in app you can turn off the BMS
can't add a switch to shutdown or turn off the BMS"
Yes, not good translation on my end. Sorry.
I thought that if both are from the same seller (IC GOGOGO Store), maybe have simillar brainbox inside, maybe same way to turn on is also the way to turn off (only for longer press).
But if seller officially says it will not work, then i would trust him...
He is chinese, it there was a way to do it, He would market it like hell, make it a selling point, increase price because of it... "look at our glorious bms, it can turn off, look look! nobody else can do that etc."
You know what I mean... Ať least thats my experience, lol.
Right now the only way i can think of, is to open up the board and identify the trace which powers the brainbox. Cut the trace and solder extension wires with a manual switch between them...
But honestly said, I personally would rather skip the turn off function completely, than to mess with traces inside like that...
If turn off is just for long time storage, maybe put a large ring terminal (screw connector?) between bms and battery, and disassemble before storage.
