greasypants
- Joined
- Mar 10, 2007
- Messages
- 98
I have not posted on here for a long time but I have been busy building up a new bike over the winter. The new bike will have 60 psi cells configured in a 30s2p pack. They will be charged as 2 15s2p packs. I have built two 15 cell Goodrum BMS boards and will be mounting them in a small pelican case bolted to the top tube.I am using 20 gauge silicon wire for the cell monitoring connections. For charging I am using two 60 volt 3 amp cc/cv variable bench supplies.
First questions is can I leave the two packs connected in series while charging? I am hoping I can just disconnect the main power to the controller and then open up the pelican case, hook up the two power supplies and charge both battery packs. 42 cells with be in one box inside the frame and the other 18 with be mounted in another box suspended below the downtube so there will be one connection between the two packs sealed inside the main box.I could run wires outside the box to easily disconnect it but I would prefer to avoid that if possible.
Second question is regarding the length of the monitoring wires. As some cells will only need a short piece of wire because they are close to the BMS and some will need almost 3 feet of wire because they are much farther away. Using a wire resistance calculator from the internet it says 3 feet of 20 gauge copper wire will have a voltage drop of .0156 @.5 amps. Would this mean the cells farther away would be charged to 3.67 volts and have a low voltage cutoff of 2.12 volts? Could this cause a problem over time and would it be better to make all the wires the same length so every cell is charged to exactly the same voltage?
Thanks
Greg
Thanks
Greg
