hillzofvalp
If anyone wants my 1 Farad digicap 20V rated, pm me. It's a Rockford, one of the best
RLT said:What about just charging a capacitor bank to the desired voltage, then disconnecting the charging supply. Fire the caps through a SCR and let the caps drain completely
Yeah, that's one of my less than elegant solutions. I thought of using two foot switches, one to power the charger... Or maybe rig some sort of two stage single pole double throw switch. in one foot control.
Gotta be a better (but still cheap and easy) way.
texaspyro said:hillzofvalp said:K. Care to elaborate? What do you recommend for the ratio between pulses and the width? I'm having better luck right now at 440 microseconds first pulse and 2000 microseconds second pulse. You want the first pulse to be say around 800 microseconds and the second pulse to be like 3000 microseconds?
BTW I just obtained a 20V 1F monster cap to try.. didn't you say these were the best?
I seldom weld by time anymore. My welder lets you specify the energy to put into the pulses. This helps compensate for things like inconsistent connections. As a general rule you start doing single pulses of increasing energy until the material starts sticking and then back off some. Set the delay to the main pulse to the length of the first pulse, and the time/energy of the main pulse to 4-5 times the first pulse.
Monster Cable and Rockford 1F caps work very well. Avoid the Rockford 2F and larger caps... they are "hybrid" caps that don't work for welding.
spinningmagnets said:I am not experienced with spot-welding strips onto cells (I've never done it), but I'd like to share some info I have found during my research.
Some of the professional battery packs made from 18650's have a split in the center of the strip, just where the end of the cell touches it, and right where the spot-welds occur. I had my theories, but recently I had someone in the industry respond to me and he indicated that the split creates a situation where the shortest distance for the electricity to travel across the electrodes during the spot-welding process...is across the battery tip, as opposed to most of the current traveling through the strip, which would leave a weak weld. Doing this results in a more consistent quality of spot-weld.
