Chalo said:
11t freewheels are an inherently bad solution to the problem of too-low gearing. They are not a terrible thing to have when the 11t sprocket is used appropriately, which is just once in a while.
The main issue is that chain wear and friction increase nonlinearly as a sprocket diminishes in size, becoming measurably higher with each increment below 21t, and becoming problematic below 13t.
With e-bikes, small sprockets become a problem because the bike is run in high gears much of the time. If you run in top gear very much, you'll just chew through a lot of chains and 11t freewheels, accelerating the wear on your chainrings as you do so.
11T Durability?
I've been running a DNP 7spd 28-11T on my eZip for 4-5 Summers, +5500 miles, with no problems or visible wear.
I do tend to pedal constantly, in 11T probably 80-90% of the time ... I cruise between 18-22mph.
The DNP 11T's, both Epoch and Long Yih are a solid steel with a heavy nickel plating.
After +5500miles there is no noticeable wear!
After cleaning, my 11T sprocket still has it's shiny nickel plating. ... Yes I do use it ...
Almost daily I push the bike to near 30mph. (Motor only is 22mph and motor assist stops at 24-25mph.)
No chain problems either. Same chain - 5 years!
Of course I do keep my chain lubricated, with "Finish Line Wet Lubricant" for the past several years.
Maybe "proper" lubrication avoids your problems?
I "clean" my chain with WD-40, then wipe down and dry with a hair dryer.
With chain nice and warm, I drizzle on the "Finish Line" and continue turning chain as I spread lubricant with a small brush.
"Hot chain" treatment seems to spread the thick lubricant into every bearing point.
After a little "run in" (couple miles ride), I wipe down the surface of the cool chain. - Don't want grit sticking to the chain "rollers".
Personal experience?
DNP 11T sprockets are nice and durable!
No apparent chain damage.
7spd 34-11T gives a great 3:1 ratio range - great for a single front sprocket!
(2008 eZip Mountain Trailz w/16T & pumped to 37V w/7spd 34-11T - 30mph capable - +3500 miles)
PS - The 9T motor sprocket, doing much more work, has no remarkable wear, ... or chain damage. ... ???
Same lubrication regime.
