dingo117
Hello people, I am from Australia and have recently started myself an e-bike project (in this damn summer heat!) and this forum seems to be plentiful in similar enthusiastic users so i look forward to learning and doing a lot from every one! but to the point i have an issue:
I recently bought a new LiFePo4 48volt, 10amp battery with BMS and charger from ebay, the seller was 3wvpowerhk and seems to be their own "make" of battery pack, clearly with other brand cells and electronics they just seem to have put it all together.
But it was fully charged when i got it, around 56 volts, i have been using it on my 2400 watt electric bike for a few days, i haven't charged it as i was waiting to run it down to see how long it will last, on the last day it shows full power on the e-bike kits volt meter, i got for a ride for 20 or so minutes and it all of a sudden shows empty, and no longer is able to power the motor, i know lifepo4 has a sharp voltage and current drop so i thought it was just that.
I later on proceed to check its "flat" voltage its around 46 volts charge, i try to charge it but on a 6 amp charger after 6 hours it wont charge over the same voltage, i decided to check each cell voltage, by removing the lid from the BMS and using a multimeter one prong on the negative, and the positive on each of the cell balancing wires going to the circuit board.
the cells marked with <<< are the cells of interest, and clearly the negative one i think is stuffed and may need replacing.
cell:
1. 3.29 (3.29)
2. 6.59 (3.3)
3. 9.48 (2.89) <<<
4. 13.08 (3.6) <<<
5. 15.67 (2.59)<<<
6. 19.00 (3.33)
7. 22.2 (3.2)
8. 25.5 (3.3)
9. 28.8 (3.3)
10. 32.1(3.3)
11. 34.8 (2.7)<<<
12. 38.1 (3.3)
13. 41.3 (3.2)
14. 40.9 (-0.4) <<<
15. 44.1(3.2)
16. 47.4 (3.3)
i got the cell voltage by subtracting the voltage from the previous cell from the reading of the current cell, i hope this is right! but one cell seems stuffed, any ideas? and use i have the BMS connected properly most of the time, sometimes i bypass the BMS when using the bike but i always connect it afterward, and i used it for the charging.
cell:
1. 3.29 (3.29)
2. 6.59 (3.3)
3. 9.48 (2.89) <<<
4. 13.08 (3.6) <<<
5. 15.67 (2.59)<<<
6. 19.00 (3.33)
7. 22.2 (3.2)
8. 25.5 (3.3)
9. 28.8 (3.3)
10. 32.1(3.3)
11. 34.8 (2.7)<<<
12. 38.1 (3.3)
13. 41.3 (3.2)
14. 40.9 (-0.4) <<<
15. 44.1(3.2)
16. 47.4 (3.3)
