izeman
1 GW
I got one of those xiexiang Bluetooth BMS connected to a 16s solar battery (connected to a photovoltaic system)
And for one cell it's cell voltage monitor shows super strange values. Under load the voltage goes down massively, and while charging it goes up.
Would be totally fine, but measuring the voltage with a Fluke DMM directly at the cell terminals shows no voltage change at all (well slowly raising/declining of course during charge/discharge).
I'm just monitoring the highest and lowest cell in the screenshot as those trigger the HVC/LVC.
As you can see the lowest cell fluctuates minimal (as expected) and this one cell (which shows no fluctuation directly at the cell terminals) jumps from 3.2V and 3.7V. 3.7V would be super critical for LiFePo4 if it was real - but as said - it's not.
Any idea what could cause this strange behaviour? I don't have a second BMS here to test this out, but maybe I will need to get one.
And: This phenomenum got worse over the last days. Voltage was jumping, but not from 3.2V to 3.75V with a super low 10A charge. And immediately dropping to 3.2V as soon as the load goes away.
Internal resistance of all cells is also as expected between 1-2mOhm.
Here's a pic showing how it became from yesterday to today:
