Hi everyone!
Im currently trying to stuff thicker phase wires into the axle of a qs205.
I plan to remove the stock wires shown and insert slightly larger gauge after removing the thick silicon jacket and heat shrinking it with PTFE high temp silicon heat tubing.
I have 2 questions.
1. Regarding the red cicles, i believe QS motor has that green paper and woven fabric going through the whole axle as insulation Im assuming.
Can this be removed since Ill be using high temp heat shrink tubing?
2. Regarding the yellow circle, do you think that wire surface is anything to worry about?
I will have to cut the oem phase near that connection point.
Thanks in advance!
I have 2 questions.
Thanks in advance!
