spinningmagnets said:Is there a simple on/off switch I can put inline on one of the balance leads so I can turn the cell-log off, without unplugging it?
auraslip said:Does anyone know the part number for the differantial amplifers on the front end? ww1 97 or ww1 9n or something?
I burned them out, and would like to see if that fixes my problems.
bobale said:One more thing I've just noticed. If you connect 2S battery it will boot up and read voltages just fine. If I connect 3S or more (so now voltage is going throught burnt D3) it displays Err: Cell volt. So now I'm puzzled. Obviously something else apart from D3 is damaged because it won't power up on 1S battery, but it boots just fine on 2S and reads correct voltage. :?
interesting I did not realize that would result in failure.bobale said:Ballance plug was connected wrong way.
I've just checked and you were right, lower part of D2 is also blown.fechter said:Probably half of D2 is also blown or one of the traces going to it. D2 feeds power to the regulator from the cell 1 pin.
auraslip said:Just to confirm - http://www.mouser.com/Search/Refine.aspx?Keyword=BAT54C
this is the diodes on the front end?
And this is the "optocoupler" on the output http://www.mouser.com/Search/Refine.aspx?Keyword=BC817-40
really it appears to be a transistor.
