Secret1511
I orded 4 6s lipo 25c from hobbyking.
What kind of charger do i need?
I like to charge the battery as quick as possible.
Ypedal said:how to you intend to arrange them .. volt / ah.. ?
48v ? 100v ?.... 24v
dnmun said:you can wire it up as one battery and use any of these for the BMS:
http://www.bestekpower.com/444v12spcmbmspcbforli-ionli-polymerbatterypack/
and you can use a regular 36V lifepo4 charger adjusted to 49.8V.
the D132 is $29. i have prices on some of the others too if you need.
dogman said:A good starting point would be a decent RC charger of at least 6s, or 8s which would be 150-300w in power. 300w will charge pretty quick. 14s hyperion chargers are poplular.
Why? This setup is a great multi chemistry multi voltage charger, that I assure you will have other uses down the road. Balancing one pack instead of the whole pile for example, or charging your car battery. Perhaps not perfectly convenient, but it will charge whatever you get in the future.
Then later, if you wish to get into bulk charging or additional bms use, then you spend more for that. But your initial purchase of a power supply and an RC charger will never be wasted money. It's just so useful to have a tool that charges everything you ever get.
dnmun said:but you still have to buy a power supply to power the balance charger. and it costs $170!!
you can buy a BMS and really large bulk charger for a lot less. but you gotta do what you you gotta do. when they say you gotta use a balance charger there is not much else to do but spend the money.
dnmun said:the D131 is $58 and can handle 80A continuous and 180A at cut out. but several of those 12S will handle that much current, 50A, before cut out. even my D126 will handle 50A at cut out.
