I have this charger that had a short in it somewhere. It kept blowing the fuse as soon as I plugged it into the wall. There are 8 components tied to the wall with plates and screws. I thought that one of the plates might be touching a component's leg as they come pretty close, but I couldn't find one touching. Everything is very tight for space, so I couldn't get my probes to the legs to check while the plares were in place. I've removed the plates now to take the photos and now the charger is working.
With the plates removed, the components are no longer tied to the case, so there's two possibilities. A component should be insulated from the case, but is making contact or one of the plates was touching something it shouldn't.
Can anyone tell me from the photos which components should be insulated. Unfortunately, it's not possible to read their designations because they're covered in white stuff. Hopefully, somebody can say from the layout what they are, but from the markings on the PCB, in the first photo theyre a bridge rectifier, transistor, transistor, then two grey plastic coated transistors. On the other side, a grey platic thing marked U70 that looks the same as the transistors on he other side, a diode an a transistor. You can click on the photos to see them in full.
Thanks for your time
