In my theoretical battery pack, the 8mm wide flat copper bars cross the 10mm wide nickel strips, so the contact area for 20A is 80 Sq mm.
This current needs to travel through 6mm length of 10mm wide pure nickel strip (0.20mm thickness) to get from the center of the cell tip, to the edge of the nickel-plated copper series bars.
Just a side-note, I found bare solid copper wire in 8-ga for 500-ft roll at $150, so...$0.34 per foot, which can be compressed into bar stock. Which is $0.04 per inch/25mm
1/16th inch thick (copper bar-stock/plate) is 0.065" thick, which is 1.6mm thick. that looks to be a fruitful hunting ground, since cutting it into strips of 8mm wide X 1.6mm thick is somewhere around 12.8mm squared in cross-section, equal to somewhere around 6.5-ga
edit, found 0.032 thick (1/32nd", 0.8mm) X .375" wide (9.5mm) copper bar stock, for 5-cents per inch/ per 25mm of length, so...0.8mm x 9.5mm = 7.6mm/squared in area cross-section, equal to 8.5-ga solid copper wire. https://www.etsy.com/listing/231678857/copper-flat-bar-stock-375-in-x-36-x
30mm long [1.2 inch] x (3 per P=group X 14S = 42 plus 6 for end caps ) roughly 60 inches? so a 14s / 6P pack would take $3 worth of bare copper bar for series connections equal to 8.5-ga (70A continuous?)
Here is same price, but narrower at 0.25-inch wide (6.3mm), and at 0.32-inch/ 0.8mm thick, its equal to 5mm squared / 10-ga (good for 50A continuous?)
Home DIY of the nickel-plating is always an option, but how to get a factory to make a thin nickel-plate? And at what price?
In the pic below, I just grabbed a pic from ES, and then drew-in two copper flat bars (for the series connection) where I would make the series connections (possibly nickel-plated and then soldered onto the nickel paralleling strips. The two red arrows point to how this builder only made the series connection with a single nickel strip of the same material and thickness as the paralleling strips:
These are high-current cells, so those single-path nickel series strips were being asked to handle 80A peaks...
