This conductive grease is a nice idea. I would like to bring up the consideration of galvanic
electrolysis. ( is that redundant?) . That is, if you have copper against nickel , that has
a potential to cause corrosion issues. Now, if we introduce carbon into the interface,
will this decrease or accelerate the increased resistance/corrosion over time of this connection?
Now, remember , this junction has a lot of amps going through it. It is not just an
electrochemical potential between dissimilar metals. Maybe what I am trying to bring up is,
maybe, if this grease idea is workable, it might be better in the long term to just use nickel
interconnects to match the battery's nickel terminals' electro-potential.
Just throwing it out there, the electro-potential tables need to be looked at.
As a side note: There are commercial products made of small beads of nickel that are made to
be used in epoxy bonded joints. The beads make the electrical connection by way of point loads,
and the epoxy is the structural joint component. Maybe a grease with this product might
hold some potential ? ( not as sexy as carbon nano-tubes though! )
Bob K
