deepfraught
Hi folks, I had a couple button sticking instances that meant friction drive bouncing/spinning under max load for a few seconds on two separate occassions.
Having a bit further bad luck two of the screws came loose so I removed it mid-ride. That meant I spotted/smelt the single burnt winding varnish, connected to one of the phase wires (red one in this case). The copper wire didn't look melted at weakest point, but the varnish looked well stuck all over in grey colour up to little burnt droplets that wouldn't shift with a cotton bud prodding.
The motor still runs and soon on my commute home will have dry road to resume testing under load.
I'm wondering what I should keep my senses out for if I was to notice anything different? The 50mm in question on the left, next to the 63mm "tank" on the right I may try if it fits.
