addicted2climbing
- Joined
- Aug 25, 2011
- Messages
- 212
Hello All,
I have been on and off this site doing research for some time and I am finaly ready to take the plunge and build a bike. I am also currnetly working on electrifying a flexboard as well using R/C components, but these questions are aimed toward an E-Bike. Anyhow, I had been considering buying a Magic Pie for the front and electrifying a bike with a rear Alfine hub but after research on here I see there are better alternatives and also another option is build or buy a reduction unit instead of the hub motor option. I am beginning to lead towards the non hub motor and possibly buying a Nuvinci developers kit instead of a bike with an alfine hub. Before I head down this road I was curious as to the pros and cons of a hub motor bike in relation to a electric motor with a reduction then coupled to the rear wheel. Also I see there are direct friv ehub motors as well as the geared hub motors by BMC.
My goals are a bike that has a top speed of 30mph, but I imagine most of my riding will be more around 20mph. I would like a range of 15 miles on a charge to be able to use it as a commuter. That range is fine if I also need to pedal to conserve energy to get the 15 miles. Mostly flat ground. One issue is I am heavy at 225lbs.
I would like to convert a bike with 700C or 29'r MTB rims and road tires. For batteries I would like to use Li-pos or A123 batteries.
These are just rough specs to pose to those in the know to see if it makes sense to go one version or the other based on my aplication. I have access to a CNC shop here at work and I can design any brackets or drive components needed in Solidworks. So what are the pros and cons of each style? Also if there is a thread with this info already feel free to post a link. I am sure price is an issue as well, but if it were not which would make more sense...
Take care,
Marc
Take care,
Marc
