420b said:So I think I'll buy some new 4110 FETs from here: https://www.ebay.com/itm/20Pcs-IRFB...959999?hash=item3ae1a7973f:g:KcAAAOSw7UZbPh9N
420b said:big whoop. it’s been 8 days and the seller has been unresponsive. So I’m going to order a new one.
exe said:420b, have you hooked up the low and hi breaks yet? I tried the low break and all it did was cut throttle. I want to confirm on how to connect hi break. I assume connect d" wire with battery + terminal or a 12v power supply?
Your three speed switch, what method is it using to get the motor to go faster? I am wonder if it switches to sensorless mode to get going faster.
Hi. What is your desired result? Are you looking for motor cutoff or electronic brake?exe said:420b, how did you test the hi and lo breaks? The low is two cables and you just short it to engage, but how did you connect up the hi break?
exe said:My understanding is that the Hi brake needs to be connected to either 12v or higher (pack voltage). I am waiting for my DC-DC converter to get 12 volt and connect it up and see if it will do regen. I do not believe it will be just cut off, but don't know for sure, will find out and report back.
