yes. Release date is August 2017. You can buy a bare motor or the kit. It will include:
- CB120 Motor incl. KTY83 temperature probe (10k thermistor for CA-V3 is optional), HTD belt pulley, air/Statorade cooling system, incl. airduct and rockfall/dirt motor protector
- BB-Mount Kit (68mm..73mm only) incl. Truvativ ® ISIS GigaPipe Bottom Bracket, cranks, chainring spider
- Kelly KLS7218S Controller, 90V abs max and 200A max phase current, factory tuned
- junction box incl. all necessary connectors, CycleAnalyst V3-DP ready, with some extra space for optional 12V converter and some space for excess cable length, mount kit
- HTD belt pulley for the rear wheel, 203mm shimano disc brake rotor, spider and bolts, pre-assembeled
- Gates PowerGrip GT3 ® HTD-belt
- waterproof thumb throttle, hall-type, 1...4V output
- second thumb throttle for variable regen brake control
Optional Products:
- Watercooling Kit, incl. radiator, fan(s), pump, water vessel, tubing and combined fan/pump controller, mount kit
- CycleAnalyst V3-DP
- PAS, only with the CycleAnalyst V3
- mount kit for CycleAnalyst V3-DP, 1-1/8" or 1.5" forks
- 12V converter, 5A max, 90V abs max input voltage
- Highsider ® Satellite 55mm mini low beam headlight, E4 approved, only 8W power consumption at >1000 lm, extra flat light profile for best vision
- Highsider ® Satellite 55mm mini high beam headlight, E4 approved, only 12W power consumption at >1500 lm
- Combined high and low beam mount kit for 1-1/8" or 1.5" forks
- 42t single chainring, 7...10 speed compatible
- key ignition switch with optional handlebar lock, mount kit for 1-1/8" or 1.5" forks
optinal wheel products:
- custom Shimano ® FH-525 rear hub with custom chromoly solid axle
- pre-assembled wheel, shimano rear hub laced into a Mavic ® EX729 rim with 13g DT-Swiss spokes
- Schwalbe ® rim tape
- Continental ® 2.5-26" tube, standard Schrader valve
- Heidenau ® IRC moped tire 2.25-22" (same dimensions as a 2.5-26" MTB tire)
- pre-assembled Front wheel kit, compatible with 15mm and 20mm through axles, disc brake compatible. rim and tire are the same as for the rear wheel
Optional products that are NOT available in August, release date is to be announced
- battery, 13s14p, 48V, 2000 Wh nominal, 140A max discharge current, max 40 A charge current (100A pulse current is OK for max. 10 seconds). Li-Ion battery, incl. BMS and aluminum case, preassembled, frame mount kit
- reinforced Eltek ® Flatpack-S charger, 1800 W, 85 - 300 VAC / 85 - 250 VDC, for 13s Li-Ion batteries with BMS
- Tektro ® Dorado rear Brake kit with variable Regen sensor, hall type 1...4V, E4 and DOT approved
- Tektro ® Dorado front Brake kit with motor-cut off contact, E4 and DOT approved
- LED Indicator kit incl. mount kit and flash controller, 12V, only 3W max consumption, E4 and DOT approved
- combined LED brake light/ LED rear light, incl. mount kit, 12 V only 3W max consumption, E4 and DOT approved
- Mirror Kit for 25.4mm or 31.8mm handlbars, E4 and DOT approved
-mudhugger ® mudguards, fits every MTB frame&fork, mount kit
- rockfall protector for the headlights (not E4/DOT approved!)
- tubeless kit for the wheels/ tubeless, pre-assembled wheels
- SRAM pedal drive kit incl. left hand grip shifter, cables, derailleur and 8-speed cassette (11t...32t)
A seperate for sale thread will be started as soon as the products are available for pre-order. Please keep this thread clean of any discussion concerning ordering those products. Thanks
