greasypants
- Joined
- Mar 10, 2007
- Messages
- 98
I just received my crystalyte 18 fet controller from Max that came with the pigtail for the cycle analyst. I replaced all the phase and power wires for larger gauge wire, replaced the the caps with 160volt caps and changed out the resistors so it will run at 100 volts. Every thing works fine but for some reason the cycle analyst speedometer doen't work, it just reads zero all the time. I checked the connections to my two older controllers and two of them are different on the new one, the green wire (throttle override) goes to a pad labelled SLA and the yellow (speed ) wire goes to a pad labelled HE. I tried moving the yellow wire over to one of the hall sensor pads but that didn't work. Anyone know what I need to do to get the speedo to work?
Thanks
Greg
Thanks
Greg
