I took my bike out yesterday for a 10 hour caching marathon; 100-odd caches.
When I started out, the motor wouldn't run until I'd gotten up some speed, which was a bit annoying, Then, after about an hour, it refused to run at all. So I stopped, changed the cable from the batteries to the controller, in case the problem was my switch or the wattmeter. No joy.
So I took the duct tape off my mess of connectors, and had a look. Nothing looked loose, but I wiggled and pushed things anyway. Still no luck when I tried the throttle. So I decided to go back the the car, and go home, so I could investigate this properly.
A couple of dozen yards into my trip back to the car, I tried the throttle, and the bike responded. And I spent the rest of the day, about 9 hours, using a bike that ran perfectly.
I have no idea what was wrong, or how I fixed it, unless it really was a loose connection. If somoene described this to me, I'd say "Loose connection".
I've replaced the plastic box that I use to cover the mess of connectors, with part of an old inner tube, an idea that I got from this forum. Problem was, there are so many connectors, the inner tube wasn't big enough. So I used two inner tubes!
