Sunder
Hi all,
I'm building a 8S23P battery at the moment, and I'm at the stage where I need to connect the "S"s to each other. I won't mince words here, the cells are crap. They're 1C rated LiFePo4, and I think even then, the manufacturer has exaggerated. Each 5Ah cell is about 140mOhms, and after soldering 23 of them together, each 23P pack is still about 6mOhms. Not a lot of point to this, except to say that I'm not massively worried about underspecing the joints, unless it gets so hot as to melt the solder. Then I'd be worried.
I had read on here that 8mm x 0.15mm nickel strips used to spot weld 18650s and the like can carry 6A. I was hoping to do 50A sustained, with 80A bursts through this battery, so it would seem that I should solder at least 10 - 14 of these strips to the battery. Each of these strips is 5cm long, but there's about 1.5cm contact with the tabs on either side, and 2cm is actually in free air.
So, just asking the question... Should I just make a massive thick pile of these into a kind of link, or would I be better off soldering one or two on the battery, then layering maybe 2-3mm of solder on top of it to do the real conducting? Basically, I'm trying to get out of work... Been building batteries for my electric bike, my electric motorcycle, my dad's farm (this one), and even a buffer battery for an inverter in my car the last month or so, and I'm sick of soldering. Gone through about 1/2kg of rosin cored solder, and 1/2kg of plumber's stick solder in the past month.
What I'm really asking is for someone to give me permission to "cheat" and shortcut this job.
