markobetti said:
i look forward to you build ( read : documented with a lot of juicy pics) with this motor.
Well buddy, that time is alot closer to happening, i just got back from forking out
$AU235 for enough 4130 chromo to build a new frame, a replica of the current frame minus
the kinked tubing as ThudSTeR hooked me up with a new roller bender from Harbor Freight he 'da MaN!
re: the Chromo tubing for the new build, front half i have gone with 1.5 x .035inch tubing which is ~38mm the current
frame has 32mm 1.2mm wall thickness tube, the weight difference is
UNBELIEVABLE the chromo
tube is thiner and wider but SOOOOO much lighter...and of course stronger, the slightly larger diameter should give the bike
a bit of a chunky look...i hope
...in contrast For the rear chain and seat stays i have downsized slightly
i have gone with 19mm wide tubing with (.5mm wall thickness IIRC )
Its slightly thinner diameter however, we are Down from the 23mm diameter i used on original mild steel frame
Thicker than the 38mm tube wall thickness anywayz need the extra strength to stop the flexing...
RAPT
with the supplier of the tubing
Go Gear Racing The have
HEAPS of sizes and
shape tubing, one in particular caught my eye, its
'aero' tubing
cross profile of it looks like a symetric aireoplane wing, had images of frames using this rushing through my head
when i was at the shop, the fella that served use was excellent, said he has had alot of fellas in buying chromo
for custom motorcyle frames, wheelchairs and even aeroplanes! I seriously think a tow able chromo wheelchair is in order
i can't keep using my new chair the tread on the tires is nearly gone and its only a month old :-S
Shall prolly start a separate worklog when i do this new frame? Will do this when the bender arrives OH ShiT! i also need another
suitable head tube..ARGH...off to order one now... i.e Ring Matt.P see if he can hook me up......yet again
ciao for now gents..
KiM
EDiT: p.s i also bought half a sheet of flat plate chromo 4130 for gussets, unfortunately they only went to 3mm which IMHO is
too thin for rear dropouts, so they will again be the 5mm variety as per used on original frame
