Rotems said:
I’m planning to buy the Cycle Analyst V3 to my mid drive electric bicycle and would like to know if it’s possible to program it to toggle between two riding modes (in a press of a button), for example:
1. Off road – the motor will work with full power (3Kw) with throttle & PAS and the configurable 3 position switch can be programed to additional options\ tuning (witch I still don’t know my needs)
2. On road – is the “legal” mode, witch limit the speed to 25Kph, limits the motor to 250W and mast use PAS.
Short answer:
Yes, but it may take a little trickery.
Long Answer:
The CA has only a single AuxPot input which can either be used to select Presets or as a Current/Power/Speed/PAS limit adjustment. Since you wish to use a 3-position switch for as-yet-undetermined purpose, you will need to switch presets using the console buttons. This is very quick but does require two hands so you need to stop to switch from off-road to legal - no issue.
What I see as the issue is that you have both PAS and throttle working on two different presets and so will likely wish two things:
- Higher max throttle power than is available with PAS (at least for the off-road mode)
- Both higher max throttle and PAS power for the off-road mode.
It's these differing PAS power settings in different presets that cause a problem.
Here's why:
- Although the V3 allows three presets, certain configuration parameters are 'global' and have a single value that affects all presets instead of being uniquely settable of each preset ('preset-specific'). With a mid-drive, you will be using a simple PAS wheel which is supported using the V3 'AutoPAS' mode. In that mode the PAS power limit is set using PAS->PASWatts. Unfortunately, this is a global parameter and so the same Max PAS power setting will apply in all presets that use AutoPAS - which pretty much fouls up high-powered PAS in the off-road setting.
That said, if you don't mind a max PAS power level of only 250W in off-road mode, then there is no issue - stop reading...
Strategy 1 (Best Control Adjustments):
This dual PAS level matter has come up before and there is a workaround: set up your legal mode normally using AutoPAS and PASWatts but set up your off-road mode using TorqPAS mode. TorqPAS is the mode used for torque-sensing bottom brackets (eg Thun). These BBs have (1) a torque signal and (2) a PAS wheel signal, so we just configure the V3 as if it had a fancy BB so we can use the PAS wheel signal and then arrange things so the missing torque input is essentially ignored. Two cool things happen:
- In TorqPAS mode the V3 will determines maximum PAS power by a different means than PAS->PASWatts so we can make the off-road setting different, and
- Unlike the AutoPAS mode, this tricked-up TorqPAS mode can be set to increase PAS power with pedal rpm.
The procedure for setting up this hacked TorqPAS mode is described in the
Guide in section 6.5 - 'AutoTorqPAS – AutoPAS with RPM-Proportional Assist'.
The suggested solution to an earlier 3-preset version of this problem can be found in
this post. Here is a copy of the image from that post that gives some deetails about a suggested seup - yours will be similar but different since that was a 12kW build, etc. In this example, the 3-speed switch was replaced with a pot to adjust PAS level 0-100% of the (different) max PAS power level in each preset.
This probably looks a little intimidating at first, but if you slog through the related sections of the Guide the individual bits should make sense. In any case, you can see the 'global' (1 column) vs 'preset-specific' parameters (3 columns). If you can't get this working as you wish, post back and we can adjust settings accordingly....
Optionally, section 6.6 'PAS Assist Control without AUX Pot – DIY Virtual Torque Sensor' of the Guide shows you how to add a pot for adjustable PAS assist in AutoTorqPAS mode AND still have a 3-position switch for power selection, etc. This is actually what I have
on my bike - really quite nice to be able to easily tune in the PAS assist and have independent control of the throttle power range.
Strategy 2 (Simpler):
Here we note that
PAS->PASWatts is superseded by
PLim->MaxPower. You might choose to exploit this by using AutoPAS mode in both presets, setting
PAS->PASWatts to the maximum for off-road use (eg 500W) and then setting
PLim->MaxPower to 250W in the legal preset. In this case the max PAS power will be:
- 250W in 'legal' mode - as PLim->MaxPower = 200W supersedes PAS->PASWatts = 500W
- 500W in 'off-road' mode as PAS->PASWatts will be less that PLim->MaxWatts = 3000W
The only issue here is that if AuxPot is used as a PAS Assist level, it scales 0-100% of
PAS->PASWatts without regard to and superseding value by
PLim->MaxPower. If using a pot this will create a 'dead zone' at the top of the pot (250W-500W in this example) and will compresse the adjustment range for the legal mode into the lower part of the pot. If the relative values are close as in this example (250W and 500W) then this may not be a huge issue. However, if they are far apart (eg 250W and 1000W) then PAS adjustments in 'legal' mode will be squeezed to a small portion of the pot and will not be very refined.
So - this second approach is easier to set up and may prove workable for max PAS power levels maybe 2x-3x between your two presets. Beyond that, PAS level adjustment will be a bit touchy.
