Hey guys,
I have my new Demo9 build which I'm very happy with, but I'm having an issue integrating the CAV3 correctly. I've dug around a fair bit trying to solve this one on my own, but I'm pretty stumped at this point. I've read through any relevant sections of the unofficial V3 user guide (which is great), but can't figure out what I've missed.
With the CA unplugged, the motor goes as fast as you would expect it to.
With CAV3 plugged in, the speed is quite restricted no matter what settings I try messing around with. Maxes out around 35k.
Details on my setup:
- Chinese hall throttle is connected directly to Lyen controller.
- 24S/100V feeding Crystalyte HT3525 (with plenty of cooling holes drilled)
- Updated to prelim6 CA firmware (flashed to b10 first, since I had the blank RSHUNT value issue).
- Throttle out is set to min 1.4, max 4.99
- 3 way switch plugged directly in to lyen controller
An ideal outcome for me would be to have the CA not having any control over the throttle, I only want the CA being used as a battery dashboard and speedo (for now).
What could I have missed? How can I maintain a direct throttle <-> controller connection and still use the CA for battery/speed?
Any ideas are greatly appreciated.
Pics or it didn't happen:
