Toshi
I test rode a Novara Gotham today at REI Seattle to check out a few things: whether a frame battery pack would fit; how the sizing runs; and how the NuVinci hub/Gates belt drive system feels.
First up, pack fitment. Here's what dimensions are required:
Here's what the L/XL frame's triangle looks like:
I think it'd work.
With regard to sizing, the L/XL didn't have a lot of standover clearance for me (not a surprise) but would certainly work for road riding. Reach actually felt too short, but that's probably an artifact of the narrow markedly pulled back handlebar setup. I certainly wouldn't want to go smaller, and slapping on my wide flat bars would probably make it nice and stretched out.
The NuVinci hub actually worked really well. The amount of slop in its freewheel is akin to that of a normal hub (but not a Chris King or modern XT), which is much better than the loosey goosey Alfine 8 that I had before. (Was it a Nexus 8? Can't recall. Shimano 8 speed internal geared in any case.)
I didn't sense an elastic feel from its innards when climbing, either, which was similarly a complain of mine with the old hub.
There seemed to be a wide gear spread, which is corroborated by this chart:
The absolute legend on the chart is inaccurate as this bike had 700c wheels and a 50t front chainring. Uh, toothring? Beltring? The correction factor should be 622/559 * 50/36 ~= 1.54, which in turn would imply a feel about the same as a double crankset road bike. That impression was pretty spot on--maybe a bit easier on the low end but the high end gears were ridiculously long. This would be perfect for e-bike conversion.
Here's that 50t beltring:
Partially obscured in the above photo is the name CenterTrack, which is evidenced by the ridge up the middle as pictured here:
Although this gave me brief hope that it'd have enough "chainline" tolerance for a mid drive setup to work +/- shimming the adapted beltwheel inwards, this guy has already tried exactly that on this same bike, unbeknownst to me (and he's from Seattle!):
http://endless-sphere.com/forums/viewtopic.php?f=28&t=65093&p=986793
Cliffs Notes are that it didn't work, due to chainline/beltline and eccentric BB issues alike.
The Gotham would still work fine with a front hub motor, probably a geared eZee since I haven't gone down that route before (other hub motors I've used were direct drive) and because they promise more torque. The bike itself is not compelling enough to warrant abandoning the mid drive concept, though, so perhaps it's back to the Surly Ogre idea.
I think it'd work.
