harrisonpatm
- Joined
- Aug 8, 2022
- Messages
- 848
Going through the planning process for my next e-moto build, and I'm considering making it a huge battery, to combat range anxiety. If space allows. Then when I think about how big it is, I realize that it's gonna need a heck of a charging setup. Currently my approx 5kwh battery can be charged on a couple solar panels in 2ish days, and I also got a relatively cheap AC charger from aliexpress that I use if I need it charged a bit faster. But by faster, I still mean 7-8 hours. Perfectly fine for now. But I really am looking in the range of 9-10kwh for the next one, as insane as that sounds, and I realize that it might be beneficial to have this capable of charging at public EV charging stations. Especially since I will likely be building this for someone else, who may want it, even though I don't.
So far I think what I need is this, a J1772 to NEMA 5-15:
https://alienrides.com/products/220-volt-ev-charger-adapter
Then I should be able to get 240VAC out of a charging station. Next, I need to find a suitable charger that accepts 120-240VAC, and outputs my battery's required DC voltage, preferably with plenty of power, somewhere in the range of 3000-6000w. I would need to mount that charger within the motorcycle build itself, and wire/plug it into the output of the J1772-to-Nema adapter. So it would need to be pretty durable, being on the motorcycle all the time. And wire the DC output to the battery. With proper wire gauge and fusing, of course.
Then for home charging, I think I need a 120 or 240V Nema to J1772 cord. So that the owner can still use home charging, and plug into their home outlet, which can connect to the bike via the same charging port. Which just again puts power into the onboard charger. That way I don't need to build a second charging port for home charging. Like this:
https://www.amazon.com/Lectron-Bundle-Electric-Vehicle-Charger/dp/B08XKDNNVK?th=1
... and there are Level 2 or 240V connectors as well, if the owner has access to 220v near their parking spot.
Does this sound like I have the concept right in theory? Any major parts I'm missing?
