I believe these figures are for straight line tension under the best test circumstances. Given aging, mechanical abrasion/wear, temperature extremes, and derating because of sharp bends, the ties seem like a recipe for trouble. For me as a consumer, the cost/risk ratio just doesn't seem to justify this approach. As a producer there are greater potential consequences and I think you may want to err on side of safety...electricwheels.de wrote:
Depending on the use:
for Pedelecs a standard cable tie will do, PA 6.6, UV stabilised, up to 600 N pull
for e-bikes with some recouperation a stainless steel cable tie, up to 1100 N pull
for e-bikes with heavy recouperation (like braking) I'd use 2 torque arms, mounted in opposite directions.
Keep in mind that the mounting point of the securing band is about 110mm out from axle centre point.
You might just replace the hook with a more conventional ring so the faint of heart can slip a bolt through it to a clamp on the stay - the bold can stick a cable tie or two through the bolt hole - everyone gets cake. If you really want to support the cable tie faction, chamfer the edges of the hole to help minimize the abrasion and sharp bend in the tie at that point.
