Johnbear
GGoodrum said:kbarrett said:An XLR connector for the power supply input would be most convenient.
What voltage input for the CMS? 36V? 48V?
What amperage? Would a standard Soniel 48V do, or would we have to get a big RC grade charger power supply?
It depends on your pack setup. There will be two versions of the CMS, initially, one for 12-cells and one for 16-cells. The input for the 12-cell CMS will be any suitable 36V SLA charger, like the Soneil units, and any 48V model for the 16-cell CMS. Most of these are 3-4A chargers, but the CMS will be able to handle up to 8A. You could also simply use a regulated power supply. I have a 0-60V 0-15A HP unit I got off of ebay for about $150, but the popular Mastech 5020 unit would also work for 12-cell setups. The optimum 12-cell supply would output 44.5-45.0V at 8A. For the 16-cell version, the optimum numbers would be 59.5-60.0V at 8A.
We are also going to offer two supplies that have exactly these specs. They are going to be provided by the LiFeBatt factory guys in Taiwan. This will allow those without an existing charger to have a complete system, optimised for the max charging rate the CMS can handle. But, you can certainly use an existing charger, or one of the lab supplies, if you have access to one.
-- Gary
This is where the sla charger with lifepo4 was mentioned. I guess it depends on the CMS.
