Sidotian
Hello every one so I have a 36v 500w ebike and a yuyang controller running on 12 s the amp draw from battery to controller is adjustable full throttle the bike is pulling 19amps with controller in the lowest possible settings...the hub motor get super hot I can't touch it for more than 3 seconds. I know from RC brushless experience that the rule of thumb is you should be able to touch the motor for at least 7 seconds I feel obviously that's just a quick test and is just ment for a "on the go" tests and isn't vary accurate ,but my main question is how hot can the hub motor stability run at with out causing damage to the motor
