EEB bomber Los Angeles
Listing for sale because I probably enjoy building more than anything.
$3800
This bike is 95% complete, just needs lighting wiring and tinkering with the wire mounting. This is your chance to save a chunk of money on a stealth Bomber. I know what everything is worth, if you don't, that's not my problem. No part outs, or trades.
The torque on this is downright ridiculous, will wheelie on command and pull up hills like a freight train.
As I continue more work on this, the price will continue to go up.
Stealth bomber frame kit 170mm Drop out (triple reinforced)
Lightweight motorcycle shocks, custom machined stem shaft to run conical motorcycle bearings, not MTB bearings
Includes two types of lighting kits. One cafe style with Halogen bulb. One with LED high/low and driving lights and LED blinkers
Hydraulic 2 piston motorcycle brakes with brake sensors
New 19" Tubeless Front motorcycle rim with new Shinko DOT Tire
2 New DNM rear shocks, 3 way adjustable 190mm
22t Freewheel
IRC GP-1 DOT rear tire
34T Crankset
KMC chain
Custom painted with top line PPG Envirobase in metallic gray
Sabvoton 72150 controller with UKC1 display, twist throttle and blue tooth.
5000w (8000w peak) 50H 5T Suringmax hub motor with 17" motorcycle rim.
Battery is a 20s LiPo
If you've ever taken apart a Nissan Leaf 7.2v 64ah cell, you'll find 4 32ah's in a 2s2p configuration but these are smaller!
Nominal voltage: 72v
Max charge voltage: 84V
Discharge voltage: 60V
Capacity: 32 Ah
Constant Discharge: 5c 150 amp continuous!
Peak Discharge: 10c
Charge rate: 3C with Daly Variable charger
Only 23lbs
Hi,
I am sorely tempted but I need to have it shipped to MN. Would you be willing to look into crating the machine? I'd prepay for delivery via LTL. Also, payment via PayPal/Venmo/Zelle. Your choice.
My request would be a build sheet. If you've already got a build log somewhere, I'll take that. I'm particularly interested in the front forks and your brakes setup but would want to know what sort of spares I should have on hand.
Lastly, is there a key or other theft prevention kit available for it?
Thanks,
Adrian
DM for my cell phone number if that works for you.
I am not currently interested in shipping. It's a lot of work to crate something like this and I'm not in a hurry to sell. It's really fun to ride when I have the time.
Finished the wiring for the DOT lights, just waiting on my DC-DC converter to show up. The lights are surprisingly bright
I don't need to look for anything, I'm not interested in shipping. Shipping ALWAYS turns into work, I have shipped every manner of things all over the globe and it's never as easy as someone showing up, handing me cash and driving off with it.
Shipping adds a level of risk, effort, and time, that I'm not interested in.
