Figured to start a new thread for the upcoming season two of commuting to work. Got some improvements in the works. El Escalador de Montaña Rojo - Season 1 for last summer's specs etc.
Upgraded motor from Clyte 4011 to an old, but "new" Clyte 504 in a 24" wheel. Got some 14mm Texas Ebike torque arms going on as well on both sides since I'll be plug braking the rear.
Removed front and rear derailleurs and opted for a single speed gearing. Not sure the tooth count etc, but it's about an 8-10mph gear to assist on the really steep parts, which I doubt I'll even need to do with the 504 running at 58.4v hot off the charger and 48A shunt. Hoping to sustain about 2.3-2.4kw for the climb.
Kinda blurry sorry, but this is the three phase bridge rectifier that will allow for a smooth braking experience. Amazingly is fits snugly with the existing allen bolt right against the frame. No heat sink needed (maybe)! Bonus!
The Steveoâ„¢ brand controller I'll be running. Converted the batt and motor connectors to Andersons.
Don't have the correct throttle and hall connectors on the Clyte motor and the ebike.ca half twist throttle so will just hard wire them all together using the ebike.ca pinout diagrams... hopefully. I'd order the right connectors, but shipping on them is more than they are worth. Hard to justify. Blargh.
Photos soon of the custom konion triangle pack at 18s7p...
