SHARKBITEATTACK
Hello, I'm a new member here and I wanted to show off my ebike project.
I had two major when designing this bike. One was that I wanted a relatively low center of gravity which means the batteries would have to be located down low. My second goal was to design a system so that the pedals and motor could freewheel independently.
I found a burly all aluminum mountain bike frame to start my project. It's an elevated chainstay design which prevents the chain from whacking the chainstays when shifting gears. It's a nice feature but the reason I opted for this frame is because it doesn't have a down tube and makes a perfect location for a battery box.
The bike will use a BladeZ scooter motor running at 36v for a total of 675 watts. Batteries will be 12v 12ah leads. The bike won't have a controller, instead I'll have to pedal, build up some momentum and hit a solenoid. The motor runs at about 4500rpm which means I would need a reduction of about 15:1. So I am using a 90 degree gear reduction from an angle grinder to give me a more suitable speed. I'm going to experiment and see what a good speed would be, but I'm thinking 20-25mph.
The hardest part of this project will be trying to make a drive shaft that connects the motor to the gear reduction. Worse case scenario is I have a machine shop customly make me one. I'm simply just going to have 2 freewheeling sprockets on the rear hub, 1 for the motor and one for the pedals. However I will try and keep all three chainring sprockets up front so I can change gearing from commuting to hills and offroading.
