silvocross said:This is artwork, beautiful build!
Thanks man, good to hear
The trouble with using any kind of pot is that they wear and become very noisy, much better off sticking with hall sensors... honestLebowski said:For my recumbent i'm going to use a cable operated throttle. I bought a Sram half grip rotary shifter and removed the ratcheting spring. At the other end of the cable will be a slide potentiometer (as opposed to a rotary potmeter). I was thinking, if you keep the ratchety bit then you can use it as a cheap cruisecontrol, when your controller is speed and not torque based that is...
Helps a lot! What should be the distance between the Magnets and which do you use?gwhy! said:I use A1301EUA-T hall sensors for my throttle conversions, if that any help.
E-Norco said:Helps a lot! What should be the distance between the Magnets and which do you use?gwhy! said:I use A1301EUA-T hall sensors for my throttle conversions, if that any help.
gwhy! said:E-Norco said:Helps a lot! What should be the distance between the Magnets and which do you use?gwhy! said:I use A1301EUA-T hall sensors for my throttle conversions, if that any help.
the mags are approx 25-30mm apart and i use 5mm diameter x 10mm bar mags (N42), if you have a larger gap you start to get a flat spot in the middle of the travel but any thing upto 25mm will be fine, or you could use longer or larger dia mags if you want a bigger gap.
E-Norco said:I ordered a A1301EUA-T hall Sensor and try to build a shifter thumb throttle to decide between this and my Magura.
Is it important to use stainless steel or can i also use aluminium for the internals?
Thinking this is well and truly buried ,,check outpost datesStielz said:This is some amazing work! Hanging out to see the finished product
dustyearlobe said:Thinking this is well and truly buried ,,check outpost datesStielz said:This is some amazing work! Hanging out to see the finished product
