lbz5mc12
I have an Electric Fat Tire Trike for sell.
Adult size
350 lb. weight capacity
48v 750w bafang mid drive
2 48v 14ah packs hooked up in parallel
24"x4" in front and 20"x4" in rear
The front suspension is basic non adjustable but actually works pretty well.
It has a rear basket.
7 speed rear gear cluster
The top speed should be over 30 mph but the sensor wire for the built in speedo isn't long enough to reach the rear wheel so I'm guessing on that.
The trike is brand new and the kit, batteries are slightly used.
Currently it only has a front mechanical disk brake. I have the parts for the rear drum brake which I had to remove in order to attach the rear assembly onto the trike; I had to remove 2 bolts but the brake was blocking them. The bolts are 2 of 4 that hold the rear assembly on the trike. All 4 bolts are on there.
I bought it for me to use but I guess I'm too tall and top heavy cause I kept feeling like it was going to tip over.
It will be local pick up only in San Bernardino, Ca in the 92405 zip code area.
I can't ship it because I have nothing to ship it in.
I'm only excepting PayPal.
See attached photos.
I'm asking $800.00 US for it.
The box in the photos is no longer there.
Adult size
