Hiorth said:So we have the board up and running, and it works nicely. Will post a detailed instruction with all cad files, part lists etc on Instructables.com this week, if anybody want some inspiration or propeller design that works you should check it out. Will post a link here, once it is up.
We will start on our V2 soon.
Action points:
- Smooth aluminum thruster casing, that can be fully disassembled
- Big Battery pack! probably 2x 48v 530 Wh + battery box for the board
- New ESC with more cooling, aluminium heatsink probably
- Arduino based bluetooth hand controller with launch control and built in battery display + safety features
- Accelerometer and other type of sensors to give feedback to the Arduino to ease operation (and for servo stabilizer)
- Safety features--> controller in water should deactivate the throttle and stop the propeller, Leash that cuts the power if released and proximity "leash" that cuts power when controller is out of range (3-5m).
-Build Foil from scratch, will add more lift to the foil wing than the Nobile wing and make it A lot lighter!!.
- Build a better and lighter Board from scratch
For fun
-Try to build co-axial propellers
- Try to build servo rodder that stabilizer the foil like a "segway", so its super easy to ride for anyone
For the microcontroller I would suggest the ESP32 as it has built in bluetooth and wifi. You could still use your Arduino IDE software to program it.
