JBallard86
torqueboards said:Have you tried the EzRun Pro 150A ESC's? They seem to work better than HK 150a ESCs.
I have not, Im hoping that the Alien Power systems twin 125 will be the ticket.
dirkdiggler said:If you are just accelerating too fast, you can change the settings on the ESC. That will help it slow down. Set it to soft start and see how that helps. Other option is to lose weight - someone told me that for kiteboarding. Never worked for me though.
Have you had issues with the chain popping on the 8 tooth sprocket? That isn't giving you many teeth to work with.
TB-
50cc is a bit of an exaggeration. 50cc is 3-4kw depending on the whose numbers you use. Those motors are really around 2500w. Probably more like 40cc, so total of 80cc for a two motor setup. Which is still quite a bit of power.
JBallard86 said:dirkdiggler said:If you are just accelerating too fast, you can change the settings on the ESC. That will help it slow down. Set it to soft start and see how that helps. Other option is to lose weight - someone told me that for kiteboarding. Never worked for me though.
TB-
I dont foresee myself loosing weight doesn't work for me either.
I dont seam to have any problems with the 8 tooth sprocket, but I do have really good alignment.
The hobbyking ESCs are set to soft start, but they still start off very aggressively.
Murfix said:Set the throttle to exponential. This means you will have less power with only a small amount of throttle and exponentially more when you give more throttle.
Murfix said:Yes, he's buried under a pile of work I think, but he always answers quickly in my experience.
dirkdiggler said:So what ESC are you using now? I thought you had the alien ESC.
on a second note I orderered those items @ http://alienpowersystem.com/ a week or so ago, it still says processing and I sent an email a couple days ago requesting an update. is he "I believe its bruno" typically pretty quick I know theres a good time difference between him and I.
dirkdiggler said:I don't know what to tell you then. In theory you shouldn't be having many issues. Wish life worked that way. The only suggestion I can think of is maybe changing the timing if you've messed with everything else. I'm about 200lbs and don't have any problems. Your deck is also probably a bit heavier too.
Hope the alien ESC fixes things for you.
