okp said:Hey... not sure I will try it as I am now .... running two VESC from Onloop BETA. I removed my APS ESC 150A (which had no problem at all), kept the APS UBEC (even if it's not needed with VESC), PowerSwitch and installed both VESC using CAN bus communication. On the following picture, 6S battery goes directly through Y of VESC for testing purposes.
I will shorten the motor wires as now I can put them more "nicely" without doing a "S" around my battery box.
Before going/riding outside on 12S:
- I need the specs from onloop on the capacitors used on the BETA VESC
- I need confirmation from Benjamin that the capacitors are adequate
- I need confirmation according to silviasol latest msg that the components used on the VESC are not counterfeit.
- (Maybe) I will add two 40A Car Fuse in series after my wattmeter (just before going on the Y of the two VESCs)
[youtube]Vg8-nZlSeDY[/youtube]
I'll follow this, still waiting for mines at least it is working with no load, that'sa good start! The motors sound so futuristic with this haha
Enjoy!
Tartopom said:Doing a top speed with such board is quite hard and frightening.
I have the same setup as OKP but running on 10S right now, my fastest speed until now is 47km/h on flat land, but I could go way faster, it was just too scary
onloop said:I also think about 45km/h is enough... its very fast on the street.
But it is also relative to your surroundings... if you are on a big open flat street, without obstacles.... maybe like a airplane landing strip or racing track you could go faster without a problem. Because you know there will be no traffic. No need to suddenly stop.
Unlike on the street, small children, dogs, cars anything can come in front and you cannot easily stop.
Also for example on tight winding bike track going through parks etc... it is hard to go top speed, maybe 35km is your top speed. It will feel like you are going much faster.
Because it is so hard to slow down quickly your speed is determined by the likley hood of an obstacle appearing from out of no where.
Always ride at a safe speed..... unless there are people riding on a bike... then you should rapidly accelerate past them laughing loudly....
okp said:crazy ! you guys are pushing it hard. I am happy with the Flywheels in 83mm... Maybe I will look to "upgrade" to Seismic SpeedVents. I cruise in Paris and the streets/roads are adequate quality.
my next plan is to dig into my board and reinforce with Kevlar fibre. Will go the dremel way and post some photos of the build soon.
